Hello, I use S32K144 when I connect the device through the USB cable to the computer, it is recognized as a flash disc. So I would like to exploit this feature to an user can store here a configuration file. How can I read the file via the S32K144 ? I tried if the fopen is implemented unfortunately not. I do not want to use some other libraries such as EAR SDK. Is it possible to read the file ? Could you get me an example? Thank you in advance.
I don't think you can read the flash disk with S32K.
This is OpenSDA Interface.
