RX Fifo Format C set up
1,355件の閲覧回数
sophie-wang
Hello NXP Expert,
I want use flexcan fifo( id filter with format c ) receive can messageI set id filter in the following code:
uint32_t rxFifoFilter[] = {FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_HIGH(0x433) | \
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_HIGH(0x512) | \
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_LOW(0x654) | \
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_LOW(0x332)    \
flexcan_rx_fifo_config_t rxFifoConfig;
rxFifoConfig.idFilterTable = rxFifoFilter;
rxFifoConfig.idFilterType  = kFLEXCAN_RxFifoFilterTypeC;
rxFifoConfig.idFilterNum   = sizeof(rxFifoFilter) / sizeof(rxFifoFilter[0]);
rxFifoConfig.priority      = kFLEXCAN_RxFifoPrioHigh;
FLEXCAN_SetRxFifoConfig(FLEXCAN1, &rxFifoConfig, true);
I think the CAN message ID I received should be 0x430~0x437, 0x510~0x517, 0x650~0x657,0x330~0x337, but the CAN Message ID I received is out of this range(0x30~0x37, 0x1F8~0x1FF, 0x230~0x237, 0x330~0x337, 0x3F8~0x3FF, 0x430~0x437, 0x510~0x517, 0x5F8~0x5FF, 0x630~0x637, 0x650~0x657, 0x7F8~0x7FF),
Why did I receive an out-of-range ID?
Can you tell me how Fifo with ID Filter format C matches received ids?
What should I do if I want to use Fifo ID filters together with individmasks?
Sophie
1,300件の閲覧回数
Senlent
Hi@sophie-wang
  I can't see from your code whether you have set the mask, and I didn't find some functions in the standard library, such as FLEXCAN_SetRxFifoConfig().
I can provide you with an example code for your reference ,but this will take a while, I need some time to test it.
BR!
     Jim,
3 返答(返信)
1,338件の閲覧回数
Senlent
Hi@sophie-wang
Can you try to set only one filter table then test it again, and attach the result.
it is inconvenient to calculate whether the mask setting is correct
I will send you a reference document by private message, you can take a look at the Chapter 3.2
BR!
      Jim,
1,333件の閲覧回数
sophie-wang
Hi Jim,
Thank you.
I have changed rxFifoFilter to the following code:
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_HIGH(0x433) | \
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_MID_LOW(0x433) | \
                                   FLEXCAN_RX_FIFO_STD_FILTER_TYPE_C_LOW(0x433)};
All ID filters are set to 0x433, It has not set RX FIFO Global Mask and individmasks.Theoretically, I should have received ids in the range 0x430 to 0x437, but this was not the case, I received ids as follows:
0x30~0x37, 0x1F8~0x1FF, 0x230~0x237, 0x3F8~0x3FF, 0x430~0x437, 0x5F8~0x5FF, 0x630~0x637, 0x7F8~0x7FF
I can't find any regularity.
1,301件の閲覧回数
Senlent
Hi@sophie-wang
BR!
     Jim,
