RD33772BJBEVM SOFTWARE CURRENT MEASUREMENT
OGUZ1
HELLO,
I AM USING RD33772BJBEVM. I WANT TO ASK A QUESTION ABOUT THE CALIBRATION OF CURRENT MEASUREMENT. FIRSTLY I UNDERSTAND THAT THE CALIBRATION IS DONE IN THE MAIN.C SECTION OF THE BASIC CODE.
Q1) IN THE FIRST LINE OF CODE THAT I SHARED, I SEE THAT THE ADDRESS OF THE DATA IS PRINT TO [FMR_ADDR](5 BIT) IN FUSE_MIRROR_CNTL(70$) REGISTER. THEN REGISTER THIS ADDRESS FUSE_MIRROR_DATA($6F) I DON'T UNDERSTAND HOW I READ IT AS VALUE.
Q2) COMING TO THE CALIBRATION PART(CASE:0x3) IN MAIN.C, WHEN WE CHANGE THE TEMP VALUE HERE, WE REACHED THE CORRECT CURRENT VALUE. CAN YOU GIVE US INFORMATION ABOUT THIS SECTION?
