when i debug s32k118 with S32DS, i can't debug like step into or step over
rootlou
when i use s32DS to debug code for S32K118,when i set jlink pwd like this,a problem happend——why  the debug into run mode,and i can't use  step into or step over button? please tell me why and how to set It?
Senlent
Hi@rootlou
Is the program running normally?
try setting a breakpoint at the begaining of the program,then reset it.
rootlou
Thanks for your replay! I have sloved it like this.Cancel it and then the mcu startup. 111.png
rootlou
i use example code below!
