is S32KDS / PE supported for S32K144 chip/evb?
I tried to configure ADC triggering synchronized with FTM (PDB-TRGMUX) with PE but is not working.
It did work with code i found in this forum but i would like to use PE .
Hello, I have similar kind of problem and still not working. My scenario is I want to use FTM0 (configured as PWM using PE) as trigger source to PDB0 using Trgmux. PDB0 has pre-triggered ADC0 and interrupt routine. FTM0 triggers PDB0 and PDB0 in turn triggers ADC0.
My understanding is PDB has to trigger source as External (PDB0_Trigger) and trigmux configuration.
Hi Enrico,
Yes, S32K144 has Processor Expert support with S32 SDK.
Can you provide the scenario that you want to configure? In this way I can provide guidelines that will help you achieve the desired functionality.
Thank you,
Rares
i would like to produce in output :
1) complementary pwm FTM0 ch0-1 used
2) indipendent FTM0 ch2
3) trigger ADC0 AN12 (PTC14 connected to pot on evb) with corresponding FTM0 trigger (init or match) using trgmux/pdb.
i can't get ADC eoc interrupt..
