Processor expert support
2,134 次查看
enricocongiu
is S32KDS / PE supported for S32K144 chip/evb?
I tried to configure ADC triggering synchronized with FTM (PDB-TRGMUX) with PE but is not working.
It did work with code i found  in this forum but i would like to use PE .
7 回复数
1,715 次查看
shripadjoshi
Hello,  I have similar kind of problem and still not working. My scenario is I want to use FTM0 (configured as PWM using PE) as trigger source to PDB0 using Trgmux. PDB0 has pre-triggered ADC0 and interrupt routine. FTM0 triggers PDB0 and PDB0 in turn triggers ADC0.
My understanding is PDB has to trigger source as External (PDB0_Trigger) and trigmux configuration.
1,715 次查看
enricocongiu
thanks, i solved my problem!
starting from ADC_HWtrigger example i added TRGMUX and FTM, with a proper clock i have been able to trigger my ADC conversion!
1,715 次查看
raresvasile
Hi Enrico,
Yes, S32K144 has Processor Expert support with S32 SDK.
Can you provide the scenario that you want to configure? In this way I can provide guidelines that will help you achieve the desired functionality.
Thank you,
Rares
1,715 次查看
enricocongiu
i would like to produce in output :
1) complementary pwm FTM0 ch0-1 used
2) indipendent FTM0 ch2
3) trigger ADC0 AN12 (PTC14 connected to pot on evb) with corresponding FTM0 trigger (init or match) using trgmux/pdb.
i can't get ADC eoc interrupt..
1,715 次查看
raresvasile
Can you attach your project?
Rares
1,715 次查看
enricocongiu
How can i attach files? it seems not possible ..
1,715 次查看
raresvasile
When replying click on Use advanced editor (On the upper right corner, above #tag button).
On the new window there should be an attach button.
Rares
