Power manager peripheral not available in peripherals configuration S32DS V3.5, S32K118 MCU
364件の閲覧回数
melvinw
I'm currently using the S32DS V3.5, S32K118 MCU and the S32SDK S32K1XX RTM 4.0.1 package plus S32K1xx development package V3.5.0. With the MCUXpresso Config Tools.
When i open the example power_mode_switch_S32k118 it's not showing the power management/manager peripheral and I'm unable to add this (nowhere to be found):
In a related topic i saw the solution was to switch to the older S32DS for ARM v2.2.
https://community.nxp.com/t5/S32K/Power-Manager-Component-not-appearing-in-Configuration-Tools/td-p/...
But i don't want to switch to an older version. I want use the current version that says it supports the S32K.
In the example it does show the header files of the power_manager.h.
Why is it not showing in the configurator? Am i missing something?
345件の閲覧回数
danielmartynek
Hello @melvinw,
Have a look at the release notes of the SDK package.
The only supported S32DS IDE is version 3.4.
Please use the 3.4 version.
346件の閲覧回数
danielmartynek
Hello @melvinw,
