PWM Generate EMIOS 0 MCL error
Dev15
Hi Team,
I'm trying to configure a below mentioned PWM output signal
eMIOS_0_CH[15]_H
It is throwing error in MCL. I have configured in EMIOS common also
Please guide here.
Thank you,
Senlent
Hi@Dev15
I see no problem with your setting and i need you to provided your project so that i can reproduce it.
Dev15
@Senlent ,
I'm not supposed to share the project. Please let me know if any screen shots of configurations required for review.
Thank you,
Senlent
Hi@Dev15
At least, you can provided me your "xx.mex" file which is not include any code but configuration only, so that i can help you to check it too.
If you cannot provide the above files, you need to provide me with detailed configuration screenshots of each component, please put them in a file for my reference
