POWER_IP_ERROR_ISR_NOTIFICATION
130 次查看
jhuang1
Hi, I am using S32DS on RTD 2.0.3, and I didn't find where to enable POWER_IP_ERROR_ISR_NOTIFICATION macro in the mex file, but  I need to enable POWER_IP_ERROR_ISR_NOTIFICATION to perform a soft reset when PMC detect a power error.
110 次查看
Julián_AragónM
Hi @jhuang1,
The McuIsrErrorNotification inside the power module declares the callout:
At IP layer, you need to defined error callback by yourself. you can look into this community post: Solved: S32K312 Power Error Notification - NXP Community
Julián.
111 次查看
Julián_AragónM
Hi @jhuang1,
Julián.
