MFRC522 connection support
akhilranga
hello there,
I am having trouble with figuring out the connection interface between my MFRC522 module and S32k144EVB.
My MFRC522module pin out is : SDA,SCK,MOSI,MISO,GND,3.3v
and the LSPI0 pinout is SCK,SIN,SOUT,PCS0.....PCS3
so help me figure out to connect which port to which.
Thank you
Tags (3)
PetrS
from MFRC522 datasheet you can see
So the connection will be below
MCU   -   MFRC522
SCK   -   SCK
SOUT   -   MOSI
SIN   -   MISO
PCS0   -   NSS
BR, Petr
