LPSPI hardfault s32k144
210件の閲覧回数
Mittal
Hii,
I am interfacing sdcard with s32k144 using LPSPI in interrupt mode.
The SDCARD read ,init function is working fine but SDCARD write function is throwing default isr.
Attaching the code for the reference.
Pls have a look.
Mudit
157件の閲覧回数
danielmartynek
Hi @Mittal,
I have just loaded and run the .elf project you posted.
But it does not end up in the Default ISR.
Anyway, can you implement HardFault_Handler() in the project?
If this is not a fault exception, read the core ICSR[VECTACTIVE, VECTPENDING] register.
