LPIT maximum achievable frequency?
777件の閲覧回数
JeorgeB
I use S32K144 and st the clock as following with using SOSC:
SOSC : 8MHz,  SPLL:160MHz, CORE_CLK: 80MHz, BUS_CLK: 40MHz;
When I want to use LPIT with input clock = CLK_SRC_FIRC_DIV1 (which is 48MHz), There is not any problem and LPIT interrupt is as which I excepted. but in RM (page 567) "Maximum frequency governed by BUS_CLK" which is 40MHz!!!
48MHz is greater than 40MHz but MCU LPIT works fine !!!
752件の閲覧回数
Robin_Shen
Please check the feedback from AE team:
We need to remember that the "Bus interface clock" (BUS_CLK in this case) is the one used to feed all the logic for LPIT, in this particular example, I see that the configuration of its registers is done successfully (using the BUS_CLK), and then, the timer starts working with its functional clock (FIRCDIV2, asynchronously).
That's why apparently there is no problem. Where problems could arise is when writing/reading the LPIT regs, later in the application.
In a nutshell, they went out of the spec, but as they kept using only the functional clock, they didn't see any issues.
Robin
