Hi, I'm trying to send Frame ID to the slave and then read request to read the data
it sends the frame id but in the read I have an issue that the operation return received NACK and there is no data send to the master.
I couldn't know how to solve this issue
that is the code:
enuRequestStatus = LPI2C_DRV_MasterSendDataBlocking(INST_LPI2C0,FrameID,1,false,OSIF_WAIT_FOREVER);
if( enuRequestStatus == STATUS_SUCCESS)
// send blocking read request (with STOP condition)
enuRequestStatus = LPI2C_DRV_MasterReceiveDataBlocking(INST_LPI2C0,pI2cData,u8DataSize, true,OSIF_WAIT_FOREVER);
could you help me in this issue please ?
解決済! 解決策の投稿を見る。
the code used should be right, so most probably there will be issue on slave side. Can you share screenshot of bus signal?
Who is a slave? Another S32K? Then what code is used?
BR, Petr
BR, Petr
yes, the problem on the testing way I used Aardvark as slave so it can't handle write and read together
but when I use another S32K142 EVB It work well
thanks for your support.
regards,
Rehab
