LIN Diagnostic Issue using LIN Stack
1,458件の閲覧回数
chaitanya_kalyani
I am using processor expert mode, LIN stack(SDK_S32K1xx_15) and want to use diagnostics for S32K116 series controller.
I checked with Both IDE S32 Design Studio V2018 as well as V2.2.
For unconditional signal there is no issue but getting issue with diagnostic signal No Response Error getting.
For checking I am sending command Read By Identifier - LIN Product identification.
Code is enabled but control is not coming to the part of the code. Same thing tested and working with S12ZVL series controller.
Thank you in advance.
5 返答(返信)
1,426件の閲覧回数
danielmartynek
maybe you send a request with a wrong value of “Supplier ID” or “Function ID”.
S32DS configuration
Diagnostic request and response on the bus
1,419件の閲覧回数
chaitanya_kalyani
Hello @danielmartynek ,
Thank you for your response.
I checked still it is not getting response for diagnostics.
and my configuration is
I am not getting where is the issue.
1,386件の閲覧回数
danielmartynek
I'm sorry for the delayed response,
Could you please scope the the diagnostic request frame (3C) and the response frame (3D) by a logic analyzer on the LPUART pins?
This is an answer from the LIN Stack SW team:
Please make sure that the conditions below have been met:
- Tick on “User transport layer” and “Support diagnostic service” on tab “Network configuration”
- Configure with the correct value of “Supplier ID” and “Function ID” on tab “Node attribute definition”
- Re-generate configuration files and compile
- Call “ ld_init()” function before use diagnostic service.
Thank you,
BR, Daniel
634件の閲覧回数
Francesco_Solito
Good morning
I have the same issue (with S32DS 3.5 instead of 2018.R1). I followed the suggestions in this post, but I didn't solve. Did you solve your issue? Could you please share the solution?
Kind regards,
Francesco Solito
581件の閲覧回数
Francesco_Solito
Hello
ld_init(LI0) was not present in the main.c of the example project "lin_slave_s32k118". Calling it before l_ifc_init(LI0) has solved the issue.
Kind regards,
Francesco
