Is IPCF not supported on statically allocated operating systems?
1,352件の閲覧回数
mikesteven
@nxp teams,
hello, I encountered difficulties with integrating IPCF.
When I set FreeRTOS only with static allocation options, IPCF compilation reported an error. Is it necessary to enable dynamic allocation?
1,007件の閲覧回数
nxf78987
Hi @mikesteven,
This issues will be fixed on the SW32K3 IPCF 4.1.0 D2312 package
Dan
8 返答(返信)
1,323件の閲覧回数
nxf78987
Hello @mikesteven,
What is the compilation error?
Dan
1,320件の閲覧回数
mikesteven
Hi @nxf78987
Thank you for your reply!
If I do not turn on the dynamic memory allocation option, the compilation will prompt the following error. Because the API used when creating tasks in the current IPCF is xTaskCreate, this function must use the dynamic memory allocation option to be used. But if my project does not allow dynamic memory allocation, does that mean I cannot integrate IPCF?
1,303件の閲覧回数
nxf78987
Hello @mikesteven,
What is the IPCF package version you are using?
Dan
1,281件の閲覧回数
mikesteven
Hi @nxf78987 ,
The IPCF version I am currently using is 3.4.0.
1,270件の閲覧回数
nxf78987
Hello @mikesteven,
I raised your issue to the IPCF team. They will analyze to this and check if IPCF driver can support also for static allocation.
I'm going to inform you when I get any information from them.
Dan
1,267件の閲覧回数
mikesteven
Hi, @nxf78987 ,
Thanks!
Okay, I look forward to your reply!
1,008件の閲覧回数
nxf78987
Hi @mikesteven,
Dan
979件の閲覧回数
mikesteven
Thank you for your notification! I have seen the modifications in version 4.1.0, thank you to the NXP team for their efforts!
