Dear NXP community,
I'm currently trying to import ECC public key into HSE FW.
OpenSSL has generated the private and public key with ".pem" extension.
So my question is, how to convert this pem file into something that could be used for key import.
Thank you for your support.
Solved! Go to Solution.
Hi @lukaszadrapa ,
Is there any reason why the first byte of the ECC public key has been removed in the code source ?
Thank you.
