Import ECC key into HSE FW
IAussman
Dear NXP community,
I'm currently trying to import ECC public key into HSE FW.
OpenSSL has generated the private and public key with ".pem" extension.
So my question is, how to convert this pem file into something that could be used for key import.
Thank you for your support.
lukaszadrapa
Hi @IAussman
0x04 is a prefix only which says that it's uncompressed format.
Lukas
lukaszadrapa
Hi @IAussman
see please attached document.
Lukas
IAussman
Hi @lukaszadrapa ,
Is there any reason why the first byte of the ECC public key has been removed in the code source ?
Thank you.
lukaszadrapa
Hi @IAussman
Lukas
IAussman
Hi @lukaszadrapa ,
Thank you for your rapid response. I've followed the instructions for generating the ECC key.
HSE FW reference manual says that we have to format the key catalog prior to any key provisioning. By doing so (format catalog), I got an error saying "operation is not allowed". In my code source LC= CUST_DEL, so I should have super user rights.
If I bypass the catalog formating, I'm also getting the same error on the key import (NOT_ALLOWED).
Do you have any suggestions ? Thank you.
Below the code:
Crypto_Init(NULL_PTR);
RetVal = Crypto_Exts_FormatKeyCatalogs();
Crypto_KeyElementSet(CryptoConf_CryptoKey_ECC_PublicKey, /* CryptoKeyId */
CryptoConf_CryptoKeyElement_CryptoKeyElement_ECC_Public, /* KeyElementId */
SEC_au8Ecc256PubKey, /*Ecc public key address */
ECC_PUB_KEY_SZ /* Ecc public key size */);
IAussman
Problem solved by setting Key_Owner to OWNER_CUST for NvmKeyCatalog, and Key Owner to OWNER_ANY for RamKeyCatalog.
