I2C Scanner using S32K146EVB-Q144
2,607件の閲覧回数
Nibesh
Hello I am developing I2C Scanner using S32K146EVB Board using S32 Design Studio.
I have develop the code using LPI2C0 and LPUART2, I am getting some problem on my code.
I have attached my code for your kind reference.
4 返答(返信)
2,563件の閲覧回数
Robin_Shen
Seems that you configure I2C ignore NACK in LPI2C_init: LPI2C Master will treat a received NACK as if it (NACK) was an ACK
void LPI2C_init(void)
    PCC->PCCn[PCC_LPI2C0_INDEX] |= PCC_PCCn_PCS(2)        /* Clk src: SIRCDIV2_CLK */
                              | PCC_PCCn_CGC_MASK;    /* Enable clock for LPI2C0 */
    LPI2C0->MCFGR1 = LPI2C_MCFGR1_PRESCALE(2) /* Prescale = 4*/
|LPI2C_MCFGR1_IGNACK_MASK; /* Ignore NACK*/
Please modify the settings and then check the ACK.
Robin
2,560件の閲覧回数
Nibesh
Hello @Robin_Shen
Will you modify my code, as I am unable to do it.
I hope to hear you soon.
Thank You
2,512件の閲覧回数
Robin_Shen
Sorry, have you modified the IGNACK settings and tested? Will the NDF(NACK Detect Flag) be set now?
Since there are many cases to be handled recently, I have not had time to modify and test your project.
2,574件の閲覧回数
Nibesh
Hello
@VaneB  @Senlent
Will you check my this thread for I2C Scanner ??
I hope to hear from you soon!
