How to write CMU driver? Is there sample code?
xiaohuang
Can CMU be configured in S32? How to write CMU driver? Is there sample code?
xiaohuang
I am using the S32K118 ,Then I don't know how to configure the CMU, how to verify that the configuration is correct.
Senlent
Hi@xiaohuang
  Can you tell me which device are you using?
  CMU is available in only S32K11x series of devices. Other products in the S32K14x series do not have CMU.
BR!
    Jim,
Ritchiehsu
Dear NXP team
My customer is VW, now RFQ status.
I see NXP Community, please give me the CMU sample code to me, Thx.
Now my 32DS setting have some problem for CMU, I don't know where problem,
please give me total 32DS setting for CMU sample code, thank you.
Senlent
Hi@xiaohuang
       I have sent you a routine in private,this demo just for your refenence.
xiaohuang
Ok, i got it, thanks you so much .I have another question, how do i test the CMU?
Senlent
Hi@xiaohuang
        Try to manipulate the thresholds in HTCR and LTCR registers,then generate a Loss of Clock reset when monitoring the FIRC.
BR!
    Jim,
xiaohuang
Thank you for the example you provided last time. How is the CMU1 threshold calculation formula derived? No related formula found on the document
xiaohuang
