How to use bootloader to update S32K14x MCU Software from USB device
723 次查看
baseerahmadpiracha
Hi NXP Team,
I am working on updating the S32K14x MCU Software from USB device. Is there any possible way or example project to understand how to implement it.
Best Reagds,
Baseer
697 次查看
lukaszadrapa
Hi @baseerahmadpiracha
S32K14x does not have USB module, so an option is to use USB-to-UART interface and then use serial bootloader.
We have this application note discussing serial bootloader. Sample code is included:
https://www.nxp.com/docs/en/application-note/AN12218.pdf
https://www.nxp.com/docs/en/application-note-software/AN12218SW.zip
And regarding USB-to-UART interface, I can recall that FTDI chip FT2232D was used on one of our EVBs.
Lukas
693 次查看
baseerahmadpiracha
Hi @lukaszadrapa
Thank you for your reply. I have successfully updated the SREC file through Java application but I am not able to run the application. I don't know whether the code is jumping to application after update or not.
Please guide me. Thanks
682 次查看
lukaszadrapa
Which debugger do you use? If you use S32 Design Studio, you can attach to a running target and then you can check the current state:
https://community.nxp.com/t5/S32-Design-Studio/How-attach-to-running-program/m-p/1030375
Lukas
