How to use S32K148 IIC Read an external EEPROM
Kevin-Roman
Hi everyone.
     I have a question,When I'm debugging S32K148 IIC read an external EEPROM.The following problems occur:
KevinRoman_1-1646016720059.png      It's going to get stuck at this point,Please see the engineer help me I want to know why
WangXiao
PetrS
so does it mean the RXEMPTY bit is never cleared?
Do you see any bytes (clocks/data) on the bus for this read sequence?
Also I guess you should change condition for while loop, this way shifting temp you can lost data value.
You can have e.g.
for(i=0;i<len;i++)
   do
       temp = LPI2C0->MRDR;
       wdtIntFeed();
   } while(0U != (temp&0x4000U));
   data[i] = temp;
BR, Petr
PetrS
You can have e.g.
for(i=0;i<len;i++)
   do
       wdtIntFeed();
   data[i] = temp;
BR, Petr
Kevin-Roman
Very grateful to youThe problem has been solved.
