How to change Main stack pointer value
1,997 次查看
AnwarSheik
I recently started working on bootloader for s32k144. I am using s32ds for arm
can some one guide me how to change the MSP value to jump from bootloader to user application
@JozefKozon @jann_ @guoweisun @TomasVaverka @lukaszadrapa
1,986 次查看
Senlent
Hi@AnwarSheik
you can refer to AN12218 and AN12218SW,
https://www.nxp.com/search?keyword=AN12218&start=0
and below demo code can be found in AN12218SW
 * Used to jump to the entry point of the user application
 * The Vector table of the user application must be located at 0x1000
void JumpToUserApplication( unsigned int userSP,  unsigned int userStartup)
	/* Check if Entry address is erased and return if erased */
	if(userSP == 0xFFFFFFFF){
		return;
	/* Set up stack pointer */
	__asm("msr msp, r0");
	__asm("msr psp, r0");
	/* Relocate vector table */
	S32_SCB->VTOR = (uint32_t)APP_START_ADDRESS;
	/* Jump to application PC (r1) */
	__asm("mov pc, r1");
