How flash to S32K144EVB
bryan_hong
Contributor V
I execute `unified_bootloader_demo_V2.1.exe` so I can find as below.
then, I try to build `S32K144_CANFD_bootloader` so I make S32K144_CANFD_bootloader.elf
For example, I want to execute application(or firmware) I modified when S32K144EVB power on.
1.
so, I want to know how to flash application(or firmware) to S32K144EVB on `S32 studio`
which type files (.bin or .elf) must be flashed to update application(or firmware) ?
2.
and S32K144_CANFD_bootloader be marked bold as below. what is mean?
I would like to know how to change the bold project to another project.
if there exist document alike `user guide for S32 studio`, plz share the documents.
3.
What is this `S32K144_CAN_user_config` foler ?
flash_api.bin/S32k144_App_CANFD.bin -> this files will be re-generated ? if so, how to generate this files?
ECUBUS_CANFD_uds.json --> What is this file used for?
thanks
Bryan
bryan_hong
Contributor V
I found `HOWTO_download_separate_elf_srec_hex_file_to_microcontroller_using_S32_Design_Studio.pdf`
btw, Must I buy below to download elf file to S32K144EVB ?
bryan_hong
Contributor V
plz answer this question and below
3.
thanks
Bryan
bryan_hong
Contributor V
If there are any update, plz comment
