Hello everyone
I am using s32k342,I configured the external rising edge trigger ADC sampling.
Now I want to sample the motor current with a little time lag on the rising edge, roughly at the position of the pwm midpoint, how to configure it?
Solved! Go to Solution.
This depend on how you generate PWM signals.
1. FlexPWM, you can use LCU to delay the measurement.
2. eMIOS - here you can use the free channel on the group which is generating PWM. You will have a synchronous 7-8 channels with same time base.
You can refer to Application note:
https://www.nxp.com/webapp/Download?colCode=AN13884
Peter
Peter
