How can I CAN RX Interrupt example ?
2,132 次查看
jaewoosong
I proceed project by using S32K144.
I find CAN RX Interrupt example in this community. But that example is not maked based on processor expert.
So it is difficult to merge my project with example. I hope to find CAN RX Interrupt example by using processor expert.
(Not polling example)
Thank you.
标记 (1)
4 回复数
1,552 次查看
PetrS
The SDK demo example in S32DS is using interrupt for RX and TX operation. You can refer to it. Examples are called CAN_MASTER_Example and CAN_SLAVE_Example.
BR, Petr
1,552 次查看
jaewoosong
Thank you for help
1,552 次查看
huaping
Dear Jaewoo:
         Have you run CAN RX interrupt example  sucessfully? If yes, is it possible to share the example?
         Thanks!
1,552 次查看
kimjunghyun
Hi. Petr Stancik.
Do you mean this code is interrupt?
* from CAN_SLAVE_Example
Kim
