Flexio Output trigger
958 次查看
584914019
The output trigger is equal to the timer output, and the signal form of the timer output depends on the working mode of the timer.
In order to ensure that the timer output can be sampled by the TRGMUX module, the width of the timer output high level and The working clock of the TRGMUX module is restricted. How to ensure it in actual application?
947 次查看
danielmartynek
The TRGMUX does not sample anything.
It is just connects one trigger source to one trigger input.
948 次查看
danielmartynek
