FTM only complementary reset on request
1,212 次查看
pietroserao
Good evening, i have a question.
While i'm using the FTM in complementary mode, only for the complementary pin, during the high period is possible to set  in low state until the next duty period only when is needed?
In other words i need to force it in low state the complementary signal only if is needed.
Thank you.
1,039 次查看
PetrS
You can use the Output mask register (OUTMASK) to force channel output to its inactive state through software. As this register is buffered you will need to use register synchronization to update the register with its buffer value. See more in chapter 39.5.13.7 OUTMASK register synchronization.
BR, Petr
1,039 次查看
pietroserao
Thank you for the answer.
I've solved using a software control. Using the FTM_SWOCTRL register
FTM0->SWOCTRL|=FTM_SWOCTRL_CH7OC(1);   // activate the software pin control
FTM0->SWOCTRL|=FTM_SWOCTRL_CH7OCV(0);   // set the pin value
FTM0->SWOCTRL|=FTM_SWOCTRL_CH7OC(0);   // deactivate the software pin control
