I'm using S32K148 EVB to test EEPROM emulation in flash.
I want to use EEE Size = 1KB so how can I configure this size in FlexRAM.
Is there any example code available to partition D flash for EEPROM data? I've tried available code but I'm not able to write data in D flash.
Please help me for this.
I'm using,
IDE : S32 Design Studio for ARM
version: 2.2
EMB02
Solved! Go to Solution.
Hi EMB02,
I am afraid you can not configure the 1KB EEE Size.
Are you test the flash_partitioning_s32k148 example in RTM3.0.3?
Robin
Hi EMB02,
Robin
