Demo Code for s32k148
1,531 次查看
bradford96789
Has the demo code for the s32k148 board been released yet? If so, where can I find it? And if not, when will it be released?
标记 (1)
1,198 次查看
nelson_lin
dianabatrlova
The link below is for AN5408SW.
AN5413SW:
https://www.nxp.com/webapp/Download?colCode=AN5408SW
When I try https://www.nxp.com/webapp/Download?colCode=AN5413SW, this site can’t be reached.
May you help me out?
Nelson
1,198 次查看
dianabatrlova
Hello Nelson,
You are right. Unfortunately, the software for the AN5413 was removed and this software is not possible to download from the NXP site. (I assume because of some updates). In the meantime use the link below.
https://source.codeaurora.org/external/s32support/S32K1xx_cookbook/
I hope it helps.
Diana
1,198 次查看
dianabatrlova
Hello Bradford,
The demo applications can be found in the AN5413:
https://www.nxp.com/docs/en/application-note/AN5413.pdf
AN5413SW:
Other documents related to S32K, see in section Application Notes on the link below:
32-bit Automotive General Purpose MCUs|NXP
Also, you can look at the demo codes in the S32 Design studio for ARM 2018.R1 in File -> New -> 32DS Project from Example.
I believe it helps you.
Diana
