Defect report on S32K144_SDK_gcc 0.8.1
1,571 次查看
tommysvensson
Where do one report issues found in the SDK?
I have found that "CMP_DRV_GetInitConfigAll(cmp_module_t* config)" does not initialize
(config->comparator).dmaTriggerState.
(SDK/platform/drivers/src/cmp/fsl_cmp_driver.c)
BRs
Tommy
标记 (1)
1,267 次查看
raresvasile
Hi Tommy,
Which version of the SDK were you using?
In 0.8.1 the DMA support was not implemented and probably that is why the field was not initialized.
Indeed this is a problem, because uninitializing the field may trigger unpredictable behavior.
But we have recently released the 0.8.2 EAR release for the SDK, which now supports DMA, so the problem was most likely addressed.
I will investigate this issue and come back with an answer.
Rares
1,267 次查看
tommysvensson
I'm using version 0.8.1.
You mention  0.8.2 EAR. Where can I find it / download it?
BRs
Tommy
1,267 次查看
PetrS
thanks for pointing this. I will notify the team responsible for the SDK.
BR, Petr
