Crypto_43_CSEC naming convention not applied (CRYPTO_MIN_MAC_VERIFY_LEN_U32)
M_SCH
Currently I use the following setting
  • S32DS 3.5.12
  • RTD (AR: 4.7.0, SW 2.0.0):
    • SW32K1_S32M24x_RTD_R21-11_2.0.0_P03_CD01_D2312_DS_Updatesite
    • SW32K1_S32M24x_RTD_R21-11_2.0.0_P04_D2404_DS_updatesite
and have eneabled and configured the Crypto_43_CSEC driver inside the ConfigTool menu.
When I build the application an error is thrown in the generated folder inside the project
  • RTD/src/Crypto_43_CSEC_Ipw.c at line 490
if( (CRYPTO_43_CSEC_MAX_MAC_VERIFY_LEN_U32 < u16MacBitLen) || (CRYPTO_43_CSEC_MIN_MAC_VERIFY_LEN_U32 > u16MacBitLen) )​
claiming undefined C macros (CRYPTO_43_CSEC_MAX_MAC_VERIFY_LEN_U32 , CRYPTO_43_CSEC_MIN_MAC_VERIFY_LEN_U32).
When I checked the generated header file inside the project folder
  • generate/include/Crypte_43_CSEC_Cfg.h at line 115 and 119
/* Minimum length of CMAC Verification */
#define CRYPTO_MIN_MAC_VERIFY_LEN_U32                   ((uint32)1)
/* Maximum length of CMAC Verification */
#define CRYPTO_MAX_MAC_VERIFY_LEN_U32                   (uint32)(128U)​
I found the macros but the naming convention is not applied here (should start with CRYPTO_43_CSEC_ instead of CRYPTO_ ).
When I checked the original header file inside the installed RTD folder at
  • S32DS.3.5\S32DS\software\PlatformSDK_S32K1_S32M24\RTD\Crypto_43_CSEC_TS_T40D2M20I0R0\generate_PC\include\Crypto_43_CSEC_Cfg.h
I found at line 124 and 127 the macros with the correct naming convention applied.
#define CRYPTO_43_CSEC_MIN_MAC_VERIFY_LEN_U32                   ((uint32)[!"node:value(CryptoGeneral/MinimumMacVerificationLength)"!]U)
#define CRYPTO_43_CSEC_MAX_MAC_VERIFY_LEN_U32                   (128U)
I have attached the files so you can check. If you need additional information let me know.
I have tried that with a second application where I added the respective driver but ended up with the same error.
M_SCH
lukaszadrapa
Hi @M_SCH
thanks for bringing this into our attention, I'm going to report this issue to SW team.
Lukas
