Code generation failed for peripherals
3,494 次查看
cw20
My project is not building because of code generation failure in the peripherals. According to the error message, no function group is selected to be the default initialization function so it will be empty. How do I fix this?
8 回复数
3,442 次查看
VaneB
Hi @cw20
When you create a new project you need to add the peripheral which you are needed at first.
After you add the related driver, then you can use the peripheral module in the IDE to configure the related module.
A possibility is that lacks the driver because when you create the project, you did not add the related driver.
Please correct me if this is not your case.
B.R.
VaneB
3,389 次查看
cw20
HI @VaneB ,
I am specifically having issues with freeRTOS and tcpip - design studio cannot find the components and that may be why code generation for peripherals is failing. I've included the log file.
3,385 次查看
VaneB
Hi @cw20
Do you have installed on S32DS the FreeRTOS and TCPIP packages?
3,372 次查看
cw20
Hi @VaneB ,
Yes, I do have both packages installed. And, I installed them in order, FreeRTOS first and then Tcpip second
3,282 次查看
VaneB
This issue could be caused by code generation timeout.
By default, Peripherals Tool has 15 seconds allocated for code generation (which should be more than enough). If code generation scripts do not finish their execution in 15 seconds, the code will not be generated.
The timeout can occur if the machine on which S32CT is running is slow/heavily loaded/code generation scripts are not optimized.
As a workaround for this issue, code generation timeout can be increased by adding the following argument into the s32ds.ini file (default path could be C:\NXP\S32DS.3.4\eclipse\s32ds.ini, it depends on the version of S32DS).
-Dcom.nxp.swtools.codegenscript.timeout = 60000 -> It will increase code generation timeout to 1 minute.
Or you can increase the timeout based on your environment.
Try this workaround and let me know the result.
3,421 次查看
cw20
Hi @VaneB,
I have included all the necessary drivers and MCALs, this is what I have:
Thanks.
3,468 次查看
cw20
Update: I've fixed the functional group error but there is still an issue with code generation for peripherals
3,456 次查看
cw20
when I build the project, there is also an issue with the tcpip library that is preventing it from building properly
