Bus Fault and Hard Fault in S32K324 Controller
471 次查看
nishanth_s12
Hi all,
I am facing the issue while eraseing the sector in S32K324 Controller.
When i am debugging the code step by step during the Erase, it works fine. When i am giving the continues run, it goes to Bus Fault and Hard Fault handler.
Kindly suggest the solution.
464 次查看
VaneB
Hi @nishanth_s12
Check the following community post. It has information related to the topic.
S32K344 C40 IP Hardware Fault Problem
B.R.
VaneB
458 次查看
nishanth_s12
Thanks for your reply.
We gone through the document.
We are unable to find  SRAM (".ramcode" section) in our project.
When we configured flash driver only, it was working. But we configured flash driver along with FlexCANPit_Ip and Port driver, it is not working properly. We are getting Bus Fault and Hard Fault.
Please find enclosed our code. Kindly rectify the same.
443 次查看
VaneB
Hi @nishanth_s12
To place the functions to SRAM, you should do the shown in the following image:
As a result, you need to see the ".ramcode" section (.map file) as follows:
