Burn hex files into external flash through S32K144
fancycang
I need to burn the. hex file on my PC into the designated location of is25q032 external flash through S32K144. Is there any software or method that can help me complete this task?
use SPI
lukaszadrapa
Hi @fancycang
if you use Pemicro tools, you can take a look at:
https://www.pemicro.com/downloads/flash_algorithm/ARM_SPI_external_flash_alg_download.cfm
I can see that IS25LQ032 is supported. Please discuss this directly with Pemicro if any help is needed.
If you have different tools, please contact manufacturer of the tools for help.
Other option is to program the SPI memory by some standard programmer before soldering or you can develop some own SW to load the data from somewhere and program it to SPI memory. It depends on your needs.
Lukas
lukaszadrapa
Hi @fancycang
Lukas
