why bsp33 /sys/devices/system/cpu/cpufreq is empty?
tomhan
hi,
I has set config as follow,but cpufreq is empty:
# CONFIG_UCLAMP_TASK is not set
# CONFIG_ENERGY_MODEL is not set
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
# CONFIG_CPUFREQ_DT is not set
CONFIG_ARM_SCMI_CPUFREQ=y
CONFIG_PM_OPP=y
MayanksPatel
Hi @tomhan,
Thank you for reaching out to us.
Can you please share board details here for which board you are trying cpufreq?
tomhan
hi,
s32g274a bsp33,thanks
MayanksPatel
Hi @tomhan,
BSP33 release does not support Frequency Scaling. In BSP35 added support for this.
Mayank S Patel
