difference between BCAN and FlexCAN
2,452 次查看
skseofh
I'm using S32G2 chipset.
What is difference between BCAN and FlexCAN?
2,437 次查看
bpe
The main difference between FlexCAN and BCAN is that the latter is controlled
by LLCE, a microcode-driven multiple core engine. The main advantage of
FlexCAN which is a pure HW, is simplicity and the option to use it as the boot
device. LLCE-controlled BCAN offers a simpler, fire-and-forget programming
model, more flexible buffer management, advanced GPP core offload services:
security (authentication and enc/dec), interworking with PFE Ethernet,
automatic CAN message forwarding. See S32G3 Reference Manual, Chapter 54 for
more information on LLCE.
Platon
2,438 次查看
bpe
Platon
