Using a watchdog in the uboot does not take effect
335件の閲覧回数
shiyiheng
I want to use a watchdog under uboot, but the watchdog doesn't work, the command is as followsshiyiheng_0-1718854066596.png
Do you need any other configuration?
3 返答(返信)
307件の閲覧回数
brian14
Hi @shiyiheng
Thank you for contacting NXP Support!
Could you please help me with your information about processor and BSP version?
Additionally, are you trying any guides or manuals as reference to use the watchdog?
298件の閲覧回数
shiyiheng
I am using the S32G platform, I have used several BSP versions to try such as BSP34, in the kernel according to the above operation watchdog is normal, in the uboot watchdog did not reset the system?
272件の閲覧回数
brian14
Hi @shiyiheng
Have you tried any modifications on Uboot build process?
It seems that the watchdog requires a specific configuration on Uboot to enable and set the time. This configuration should be enabled by default on that BSP version; however, I'm still working with the team to confirm that.
