LLEC getting started guide& firmware userguide
brian_w
Where can I find the LLEC getting started guide and LLCE firmware userguide?
Thanks a lot!
Daniel-Aguirre
The User Guide is provided once the LLCE package is installed. It should be located on the following address:
"C:/nxp/S32G_LLCE_1_0_4/firmware/llce_interface/doc/LLCE_firmware_user_guide.pdf"
It may vary depending on where you installed it, but it is given after the installation. The Reference Manual also provides information regarding LLCE [Chapter 54, Page 2450, S32G2 Reference Manual, Rev. 6, 11/2022].
Please, let us know if this information was helpful or not.
Daniel-Aguirre
Pashan
Hello Daniel-Aguirre,
After I install the software, I see the following folder as empty
C:\NXP\S32G_LLCE_1_0_5\firmware\llce_interface\doc
Can you please confirm whether the LLCE_firmware_user_guide.pdf file is present in the 1.0.5 Release Bundle?
Daniel-Aguirre
We are seeing the file available under the provided path:
Could be that it was not installed correctly.
Please, let us know.
Pashan
Hello Daniel,
Thank you.
I reinstalled and I can find the file.
