Hi, I am using S32K142 to build a project. But there is something wrong with the SDK, I want to update my current SDK. I have checked the website but there is no updatesite.zip version for this chip. Could you send me the link for the updatesite.zip version?
And the problem I have is LPSPI_DRV_SetPcs() function is not included in the lpspi_master_drive.c
Solved! Go to Solution.
Hi @Zyuan17
The latest version of S32DS is the 3.5, so, I suggest you to download it instead of using S32DS for ARM. This in order to ensure the best service from our products.
S32 Design Studio 3.5 – Windows/Linux
B.R.
VaneB
Make sure you've thoroughly searched the manufacturer's website for any available updates or downloads related to the S32K142 chip. Sometimes, the updatesite.zip file or related software may be located in a different section or under a different product category.
I have checked the website but I can't find the update.zip file. Could you send me the link of this file?
I have solved this problem. If you are using S32K for ARM 2.0Version, you need to go to the website and download the update 3 for S32K DS. And this should work.
Hi @Zyuan17
B.R.
VaneB
Hi, I took your advice and it seems like the SDK works. But I can't find the components' window now. I have checked the window->view and there is no component window option.
