Multiple ADC channel in 5746R
957 次查看
supra0309
The example is adc_pal_mpc5746r. I try to modify example program and use different inputs simultaneously (PB0~PB5 shown in figure) into MCU to get resVolts from variable "adc_pal1_Results". But there are some problems about pinsettings, commands and head files. What do they need to be used for program to achieve my goals? Thanks.
Xantia
0 回复数
