hello,
I am using SDK3.0.0 for a LIN communication .
I got a problem when I want to turn off peripherals.
The program is stuck in LIN_DRV_Deinit(INST_LIN1)➡LIN_LPUART_DRV_Deinit(uint32_t instance)➡
LPUART_SetReceiverCmd(base, false).
The LPUART_CRTL_RE is 1.When I reset it in Debug,program will runnig normally.
This fault occurred sporadically when the mcu powered on.
I have changed the clock source of LIN from SIRC to SOSC,This fault has been resolved.
I want to know the reason about this.
If you have any ideas,please answer in the comments,Thank you very much.
已解决! 转到解答。
It's not available for S32DS for Arm (which is version 2.2). It's available for new S32DS:
Newest version is 3.5. The SDK can be installed using: Help -> S32DS Extensions and Updates.
Lukas
Hi @zzkk
I just answered the same question here:
https://community.nxp.com/t5/S32K/S32K116-JUMP-TO-APP-FROM-BOOT-SOFTWARE-STUCK/td-p/1684924
Lukas
Lukas
