I use the S32K144 EVB CAN to communicate with one smart sensor.The MDK is RTM 300.
The transmit CAN frame is EXT.
I found that the CAN bit SRR must be set to 1,otherwise the communication will fail.
Now, I modify the function FLEXCAN_SetTxMsgBuff like below.
So, do you have any other way to set the SRR bit?
Has this been updated in the SDK yet? I have a customer facing this issue as well, but this was from a few years ago.
Brendan
