FreeRtos and Lin/Lwip Stack for RTD 1.0.1
已解决
跳至解决方案
4,377 次查看
christofhaiding
Hi!
I tried to convert our current S32K148 project from RTD 1.0.0 to RTD 1.0.1
In the current project we are also using the FreeRtos and Lin/Lwip Stack.
But i it seems that there is not such support for those stacks at the moment.
Do I have to download some other software packages to get this functions (like at RTD 1.0.0)?
Or are those stacks not supported at the moment?
And if not can you give me an estimate when this packages will be available for the RTD 1.0.1?
Christof
标签 (1)
标记 (3)
1 解答
4,304 次查看
christofhaiding
Hi Daniel!
Thanks for the information.
Thats what I wanted to know
Christof
在原帖中查看解决方案
6 回复数
4,352 次查看
danielmartynek
Hi @christofhaiding,
If you go to the Reference SW
that can be found here:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/s32k-automotive-mc...
You should find release notes for each SW.
For example, in the release notes of the FreeRTOS driver, you can read:
Please use it with the supported drivers only.
4,328 次查看
christofhaiding
Hi Daniel!
Thanks for the reply.
Are there any planes for a release Version of those stacks for RTD?
Just asking, because we want to update to RTD 1.0.1, but without the FreeRtos and the Lin Stack that is not possible.
Christof
4,325 次查看
danielmartynek
There are already FreeRTOS driver and LIN Stack for RTD RTM 2.0.0.
BR, Daniel
4,323 次查看
christofhaiding
Hi Daniel!
Thanks for the Info.
Correct me if I am wrong, but RTD RTM 2.0.0 is for the S32K3xx only. Right?
We are using a S32K148.
BR, Christof
4,306 次查看
danielmartynek
I'm sorry, you are right, that is for S32K3.
For S32K1 we have SW32K1 LIN stack version 1.0.1 that is compatible with RTM 1.0.1 already.
The FreeRTOS version for RTM 1.0.1 should be officially released on May 27th.
4,305 次查看
christofhaiding
Hi Daniel!
Christof
