Expected Usage of Callback Parameter?
980 次查看
gearhead1107
I'm trying to make a generic timer interrupt callback function, and use Processor Expert to specify the device that caused the interrupt.
For instance:
timer_ISR(uint8_t device)
/* Do Stuff */
In Processor Expert's configuration for the Flex Timer, I specified "timer_ISR" for the callback successfully, however it's not clear how to get the parameter I require into the function.
If I specify "1" for device 1, the compiler doesn't like that this is creating a "void * channelsCallbacksParams" of "1"
If I create a uint8_t variable for the device I want, the compiler cannot find it when it compiles the generated code
If I create an array of "userData", it also can't find it..
Some guidance here would be appreciated - I can't seem to find any help in the documentation.
0 回复数
