Crypto
Crypto
533 次查看
严雷
I am currently using the S32K144 for information security development and would like to ask how to use address mode when calculating MAC values using the MCAL version.
When I used the SDK version, there was a function called Csec_Ip_GenerateMacAddrMode that could be implemented, but it wasn't found in the MCAL version.
我现在在使用S32K144做信息安全开发,想问一下在使用MCAL版本计算MAC值时,如何使用地址模式。
我在使用SDK版本时,有一函数Csec_Ip_GenerateMacAddrMode可以实现,但是在MCAL版本中并未找到。
361 次查看
CongDang
RTD produce supports both MCAL and SDK. So you can use RTD like what you did on SDK version (it means RTD also provides Csec_Ip_GenerateMacAddrMode function like what you have on SDK version)
Please let me know if you need more details for this or you still want to use using from MCAL API.
