can_fd Example project in MPC5748G
1,179件の閲覧回数
fengyh
is there some examples about transform/receipt of can_fd frame based on MPC5748G?
3 返答(返信)
813件の閲覧回数
jiri_kral
the FlexCAN example is part of S32DS installation. On the main menu bar click on File -> New -> New S32DS Project from Example...
In newly opened window select  flexcan_mpc5748g project and press finish.
In newly opened project in the processor expert area double click on canCom1:flexcan. In configuration window enable FD and select Payload size to requested value.
When you are done - generate processor expert code by pressing icon in the processor expert area and rebuild your project.
Jiri
813件の閲覧回数
fengyh
Thank you for your help! But i can't find the flexcan_mpc5748g project,wihle there is a flexcan_recive project and a flexcan_transmit project,are they helpful?
And i couldn't find the configuration window to enable FD and select Payload size to requested value.
if i have wrote code to enable FD and select Payload size in the project,i still need to find the configuration window to enable FD and select Payload size to requested value?
813件の閲覧回数
stanish
I assume you are using S32DS for Power v1.2.
There are multiple example groups for MPC5748G  - one for examples based on SDKs (there  multiple version of SDKs)  and other non-SDK examples.
If you cannot see the latest SDK  v0.8.1 example Projects folder you need to install S32DS for Power Update:
S32 Design Studio for Power v1.2 - Update 3 available
Hope it helps.
Stan
