I have a S32K144-Q100 evaluation board( total newbie here). Just wanted to ask which debugging interface is better ? Segger Debugging Interface or GDB PEMicro Debugging Interface
What will be the differences if I choose one over the another?
已解决! 转到解答。
This setting enables the semi-hosting support and configures input/output to print information to the console during debugging.
As you are using an EVB, is not necessary to use an external debugger to flash programming unless you want it or require it.
Our EVB comes with an onboard debugger with OpenSDA, which provides a bridge between your computer (or other USB hosts) and the embedded target processor, which can be used for debugging, flash programming, and serial communication, all over a simple USB cable.
OpenSDA is programmed with the proprietary P&E Micro-developed bootloader. P&E Micro is the default debug interface app.
B.R.
VaneB
