SPI - Clock & Chip select timing configuration problem
1,209 次查看
Riyasma07
In SPI configurator, when I try to change the timing values for Clk2Cs, Cs2Clk & Cs2Cs from 0.000001 sec to 0.00001 sec, I'm facing an error.
But when I hover over the timing fields, it shows the timing can be set in the range of 100ns to 0.0001 sec.
10 回复数
1,005 次查看
Riyasma07
Hi @VaneB, Seems like it is causing problem with code. I've set the timing as 0.00003 sec and checked, there is no response from the slave.
977 次查看
VaneB
Hi @Riyasma07
Are you using an external device or is it connected to other SPI modules of the S32K3? Are you using the example code?
974 次查看
Riyasma07
Hi @VaneB ,
Yes, we are using an external device and not using example project.
957 次查看
VaneB
Hi @Riyasma07
Could you share an image of the signals coming out from the S32K3?
932 次查看
Riyasma07
Hi @VaneB,
The screenshot of signals from S32K3
914 次查看
VaneB
Hi @Riyasma07
The signs seem correct, but to make sure the problem is not caused by S32K3, please try testing the SPI example with the settings you require.
1,167 次查看
VaneB
Hi @Riyasma07
Sorry for the late response, due to workload my response was delayed.
Which RTD version are you using? Also, please provide your clock configuration.
B.R.
VaneB
1,163 次查看
Riyasma07
Hi @VaneB ,
I'm using RTD Version 3.0.0
The clock configuration is
and I'm using SPI0
1,039 次查看
VaneB
Hi @Riyasma07
Sorry for the delay.
I had verified this situation and the cause of the problem looks to be related to S32DS and not for a wrong configuration. The error should not cause any problem with your code.
1,186 次查看
Riyasma07
@VaneB  Any updates?
