Dears,
I am using S32DS3.4 to develop K144, and I want to make a new project using "File->New->S32DS Application Project", but when I choose the SDK, I cannot find the standard SDK for K1(such as "S32K1xx RTM SDK.....", although I have installed it by the related " .exe" file downloaded from NXP offical website ), detailed picture as below, the only 2 sdks shown are "AMMCLIB_S32K14x" and "FreeMaster_S32K144",please tell me how to resolve it? thx!
Solved! Go to Solution.
yes, SDK is built with gcc v6.3. If you choose higher version, SDK is not available.
do you have installed S32K1xx SDK package?
If So, please make sure that you choose correct toolchain in New Project Wizard (gcc v6.3):
if the tool chain is wrong ,then the SDK cannot be found in the next page?
hi Jiri,
I checked what you said , and just like you said , with different GCC version ,different SDK showed up, thanks a lot~
