are there any demo projects for the MPC5777C created in S32DS?
I would like to open the Example_MPC5777C-PinToggleStationery but it doesn't work.
Which is the tool used to create all the demos there?
Marco
FYI: I've just created multi-core pin toggle example.
Example MPC5777C Single ELF multi-core Pin Toggling - S32DS Power v1.2
hope it helps.
Stan
Hi Macro,
I was referring your etpu project.
I have some queries here, can you share details
1. What is the use of PIN_PT12,PT13,PT14,PT15 pins here ?
Vrushali
Hello Marco,
Unfortunately, we do not have created any example project in S32DS for MPC5777C yet.
The project you had downloaded and tried to import is created in Multi IDE from Green Hills. Please see following link.
Bad news is, that this IDE is under license.
I hope I will have a little bit of time to convert some of the examples for S32DS soon.
Martin
